Hi all I need some help With my RGB setup
I have a ASUS ROG CROSSHAIR VI HERO (WI-FI AC) motherboard
A Phanteks Evolv X case and Phanteks halos fan Frame.
I've had the halos frame for some time before the case, I could never get it to work because the person I got it from did not included the cable need to connect to the motherboard and only realised months later when I got round to connect it.
I could not get it to work, I have since purchased a Phanteks RGB strip combo pack which had the adaptor, I have just recently tried to setup the RGB after getting to Evolve X cases and moved everything over, I have ran into a few issues and I cant figure out how to set it up.
The issue is my motherboard and halos frame has a 4 pin rgb connecter and the cases uses 3 pin connector so I cant connect it to the motherboard. ive managed to connect the halos frame and got it working after connecting it the wrong way round (the connecter did not show which way to connect it and it would only work one way)
Anyway what should I do about the case how can I get it to work via the motherboard?
