Hi, I was considering buying a Phanteks Evolv X Linked here:
https://www.overclockers.co.uk/phan...lass-gaming-case-gunmetal-grey-ca-07z-pt.html
But before I did I wanted to check if it could fit the EK-COOLSTREAM CE 420 in PUSH+PULL front of the case, linked below:
https://www.overclockers.co.uk/ek-w...eam-ce-420-triple-fan-radiator-wc-99i-ek.html
Now I have heard from various sources that the case supports up to 95mm of space on the front of the case for mounting radiators but can anybody actually confirm that the combination I want fits?
I know that the radiator I linked is 45mm in width and most case fans are 25mm in width if I'm not mistaken so 25+45+25= 95mm, that means it is millimetre perfect so any discrepancy on this even by 1mm will mean it won't fit. Has anybody seen or done this themselves and can confirm it works?
Thanks in advance I look forward to hearing what you guys think
