**PHANTEKS FULL MATTE WHITE EDITIONS ECLIPSE P600S / EVOLV X**
OcUK Staff
1 Apr 2014
OcUK HQ
Available to order, the new Phanteks Matte White Edition cases from the P600S and Evolv X range as well as the Phanteks PCIe Gen 4.0 Riser Cables and Vertical GPU Mounting Bracket. Also available now are the Phanteks SK 120 and 140 D-RGB White Fans.
Phanteks Eclipse P600S Matte White Mid-Tower @ £174.95 inc VAT
Matte white mid tower, Hinged tempered glass panel, Integrated 140mm dRGB fans, All white design, Up to 10 HDDs and 3 SSDs, Vertical GPU mounting available
Only £174.95 inc VAT.
ORDER NOW
Phanteks Enthoo Evolv X Mid Tower Case - Matte White with dRGB fans @ £234.95 inc VAT
Mid tower chassis, All white aesthetic, 3 x 140mm dRGB fans, Aluminium and tempered glass, Vertical GPU mounting, Up to 10 x HDDs and 9 x SSDs
Only £234.95 inc VAT.
ORDER NOW
Phanteks PCIe Gen 4.0 Riser Cable – 150mm – 90-degree Adaptor @ £52.99 inc VAT
PCIe 4.0 riser cable, 150mm long, 90-degree adaptor, Dual layer design, Gold plated connectors, Flexible cable
Only £52.99 inc VAT.
ORDER NOW
Phanteks PCIe Gen 4.0 Riser Cable – 220mm – 90-degree Adaptor @ £52.99 inc VAT
PCIe 4.0 riser cable, 220mm long, 90-degree adaptor, Dual layer design, Gold plated connectors, Flexible cable
ORDER NOW
Phanteks PCIe Gen 4.0 Riser Cable – 300mm – 180-degree Adaptor @ £52.99 inc VAT
PCIe 4.0 riser cable, 300mm long, 180-degree adaptor, Dual layer design, Gold plated connectors, Flexible cable
ORDER NOW
Phanteks Vertical GPU Mounting Bracket with PCIe 4.0 Riser Cable @ £60.95 inc VAT
Vertical GPU mounting bracket, PCIe 4.0 riser cable, Steel bracket, Rubber anti-sag pads, 1 – 4 expansion slots, Black
Only £60.95 inc VAT.
ORDER NOW
somebody been on the lemonade at lunch time before putting this post together, between images not working and url showing it kinda looks a bit strange! :p
