- 18 May 2010
Hi,
I'm looking into the Phanteks Halos fan frames and led strips but I didn't realise RGB was so complicated, there is argb, digital rgb, normal RGB and I've probably got that wrong!
I have an MSI B450 Pro Carbon which has mystic light, Phanteks supports that which is great, it has two headers, according to the manual one is 5v and one is 12v, I'm not sure if the fan frames can be linked to the led strips and what voltages they all are
I also don't understand how I buy three fan frames of which there are different versions like Lux for example also get and led strip and link them all together into one header?
I only want them to breath slowly from white to blue I don't want crazy light shows in multi colour.
Can anyone help me understand what I need to buy please?
I need -
1 X 120mm fan frame
2 X 140mm fan frame
1 X led strip
Link them all together to one header and control via MSI Mystic Light
Thanks
I need -
1 X 120mm fan frame
2 X 140mm fan frame
1 X led strip
Thanks
