Phanteks Halos not working correctly
9 Feb 2013
Hello, I've just bought 6 Phanteks Halos to install in my new build. I check beforehand and they are RGB Fusion compatible.I have an Aorus x480 Elite AC.
On installation, I daisy chained them all up, and connected the last one to the 4pin RGB Header. The plug doesn't secure, and only fits on loose. Whatever colour I choose on RGB Fusion, these fans do the opposite. I've tried the plug upside down, on a 3pin port. Nothing works. While the worst case is that cause the plug just rests on the pins, the colours change due to a poor connection. Am I on the wrong RGB plugs? I've tried the bottom left plug, the top right plug, nothing seems to fix this issue.
Update, seems like Red on RGB Fusion is Green for phanteks. Green on RGB Fusion is Blue on phanteks and finally Blue on RGB Fusion is Red on phanteks. Has anyone had this issue before?
