Phanteks Luke
7 Jul 2008
Hi everyone trying to remove the front of my Phanteks Luxe case to remove all dust. I cant figure out how to remove it.
Any one know?
Long nose pliers and pinch the plastic clips (3) in on each side and push through slightly.
Start at the bottom. When you've done that, you should be able to pull to front off.
Mind the LED cables, not much give on them once the front is off so just unclip them.
I have the case first slide the bottom fan filter out then grab the front from the bottom and pull firmly. Takes a bit of force but it will pop out. Once it is loose at the top there is two cabled to disconnect. One for led and one for fan. I can provide pics if you wish.
