Hi,
Looking for a new CPU water block? Absolutely despise RGB? Then we have the water block for you.
Phanteks have released a non RGB Acetal water block for all the non RGB fans of the world so you can all enjoy great style and performance.
The CPU blocks come in both Intel and AMD and offer the same outstanding performance that the RGB model offers but with out the flashing lights.
The Phanteks water cooling range is expanding all the time giving you more options to choose from making your builds stand out. Phanteks are fairly new to the water cooling game but have been in the cooling business for a long time and have produced some of the highest quality cooling products on the market.
The Water cooling range includes Reservoirs, CPU blocks, VGA blocks and lots of fittings which are all linked at the bottom.
Phanteks Glacier C350IP Intel CPU Water Block Acetal Cover - Black @ £59.99 inc VAT https://www.overclockers.co.uk/phan...water-block-acetal-cover-black-wc-028-pt.html
Intel Water Block, Compatible with Intel LGA 115x / 2011-3 / 2066, Acetal, Satin Black, 2 year Warranty
The Glacier C350ip CPU block from Phanteks is all about extreme cooling performance. Made from premium materials with an acetal top and 0.4mm high density fins for the best overclocking performance. VITON O-rings from the Automotive and Aerospace Industries ensure the best reliability and longevity.
Design
- High quality acetal top cover
- Reliable and flexible mounting system for all orientations
- High quality nickel finish
- Compatible with the Intel LGA 115x / 2011-3 / 2066
Designed for performance
- Cooling fins and copper base are CNC-ED from one single piece copper with enlarged base for the best thermal capacity.
- High density cooling fans, fine tuned to 0.4mm wide and designed with extra high fins (5mm) for improved conductivity.
- High flow engineering reduces flow resistance for outstanding cooling performance.
- Extreme cooling performance and optimal heat dissipation for heavy loads and overclocking.
- Phanteks PH-NDC thermal compound with nano diamond-like particles.
Viton o-ring for high reliability
- Tailored viton rubber o-ring.
- Applied in automotive and aerospace industries.
- Improved durability, resistant to wear and tear during installation.
- Viton o-ring retains sealing performance for long periods of time.
Specifications:
- Product Type: CPU Water Block
- Compatibility: Intel LGA 115x / 2011-3 / 2066
- Materials: Copper Base, Nickel plated, Acetal top
- Water Dimensions: 90 mm x 35 mm x 90 mm (W x H x D)
- Copper Base Dimensions: 70 mm x 4 mm x 70 mm (W x H x D)
- Fin Construction: 5mm high / 0.4mm thick / 0.4mm gap
- Warranty: 2 Year
Only £59.99 inc VAT.
ORDER NOW
Phanteks Glacier C350AP AMD CPU Water Block Acetal Cover - Black @ £59.99 inc VAT https://www.overclockers.co.uk/phan...water-block-acetal-cover-black-wc-027-pt.html
AMD Water Block, Compatible with AMD AM4 / AM3(+) / AM2(+) / FM1 / FM2(+), Acetal, Satin Black, 2 year Warranty
The Glacier C350ap CPU block from Phanteks is all about extreme cooling performance. Made from premium materials with an acetal top and 0.4mm high density fins for the best overclocking performance. VITON O-rings from the Automotive and Aerospace Industries ensure the best reliability and longevity.
Design
- Compatible with AMD AM4, AM3(+), AM2(+), FM1, FM2(+)
Specifications:
- Compatibility: AMD AM4, AM3(+), AM2(+), FM1, FM2(+)
- Warranty: 2 Year
ORDER NOW
Phanteks Water Cooling Range
Design
Specifications:
- Warranty: 2 Year
ORDER NOW
Design
Specifications:
- Warranty: 2 Year
ORDER NOW
