- 8 Jan 2019
- MSI HQ
Available for preorder today, we have the newest cases and accessories in the Phanteks range - The P360X, Shift Air and Neon DRGB strips. The P360X is the updated version of the very popular P350X series, with an improved front panel, allowing more airflow whilst keeping the Digital RGB lighting on both the front panel and on the PSU shroud. Improved over the P350X is the radiator support, allowing 280mm radiators on the front panel and 240mm radiators on the top panel. 400mm VGA cards, 160mm CPU coolers and 250mm PSU's are supported, along with up to E-ATX motherboards (max 280mm wide). The ARGB can either be controlled on the I/O or synced to a compatible ARGB motherboard such as Asus Aura, MSI Mystic Light, Gigabyte RGB Fusion, Asrock Polychrome or even software like Razer Chroma. All this and the price is practically the same, stock will arrive in the next few weeks.
Next up we have the Shift Air. This is a new airflow orientated iteration of the Shift case that debuted around 2 years ago. It takes the existing Shift design and replaces the glass side panels with mesh fabric covers, as previously seen utilised on the P600S cases that launched earlier this year. This not only considerably increases airflow for the case, but helps the Shift Air blend into the living room setup as a compact yet powerful HTPC. Available in both Gunmetal and Black variants, the Shift Air retains most of the features found on the Shift, such as aluminium panels, support for 350mm VGA cards, Mini-ITX motherboards, SFX/SFX-L support, 82mm CPU coolers, dual 120mm radiator support and more. Stock should be available in the next few weeks.
Finally, we have the Phanteks Neon DRGB LED Strip Combo Set. 2 x 400mm long DRGB strips, fully addressable affording you a whole host of colour options. The combo set also includes 90 and 180 degree brackets and guides, allowing you to route the flexible LED Strips around Fans, case edges, the Strips can be daisy chained together too for a continuous, glorious RGB loop! The LED Strips can be controlled by a Phanteks Hub or compatible Motherboard software such as ASUS Aura Sync, MSI Mystic Light Sync, Gigabyte RGB Fusion, ASRock Polychrome Sync and Razer Chroma via the included 5VDG 3 Pin Adapter. Stock should be available in the next few weeks.
Phanteks Evolv Shift Air Mini-ITX Case - Black @ £94.99 inc VAT
Premium Mini-ITX case in black with optimised airflow, Aluminium & mesh panels, Space for graphics cards up to 35 cm long, Designed for up to two AiO water coolers with radiators up to 120 mm
Only £94.99 inc VAT.
ORDER NOW
Phanteks Evolv Shift Air Mini-ITX Case - Gunmetal Grey @ £94.99 inc VAT
Premium Gunmetal Mini-ITX case with optimised airflow, Aluminium & mesh panels, Space for graphics cards up to 35 cm long, Designed for up to two AiO water coolers with radiators up to 120 mm
ORDER NOW
Phanteks Eclipse P360X Midi Tower DRGB Case - Black @ £67.99 inc VAT
Stylish Midi-Tower from Phanteks with great airflow, Front includes stylish RGB strips, Side window in tempered glass, Pre-installed 120 mm fan, PSU shroud, Integrated dust filter, 2x USB 3.0
Only £67.99 inc VAT.
ORDER NOW
Phanteks Neon Digital RGB-LED-Strip Combo Set (400mm x 2) @ £17.99 inc VAT
DRGB LED Strips x 2, 400mm Long, Compatibile with ASUS - MSI - ASRock - Gigabyte & Razer RGB Programs (With 5VDG Adapter), 2 Year Manufacturer Warranty
Only £17.99 inc VAT.
ORDER NOW
Phanteks Neon Digital RGB LED Strip - 550mm @ £12.95 inc VAT https://www.overclockers.co.uk/phanteks-neon-digital-rgb-led-strip-550mm-ca-09w-pt.html
55 cm long lighting strip from Phanteks, with digitally addressable RGB LEDs, milk-transparent cover, including mounts & 5VDG adapters
Only £12.95 inc VAT.
ORDER NOW
Phanteks Neon Digital RGB LED Strip - 1M @ £19.99 inc VAT https://www.overclockers.co.uk/phanteks-neon-digital-rgb-led-strip-1m-ca-09v-pt.html
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09VPT_227783_285x255.jpg)
1m long lighting strip from Phanteks, with digitally addressable RGB LEDs, milk-transparent cover, including mounts & 5VDG adapters
Only £19.99 inc VAT.
ORDER NOW
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09JPT_225330_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09JPT_225331_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09JPT_225332_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09JPT_225333_285x255.jpg)
ORDER NOW
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09KPT_224237_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09KPT_224238_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09KPT_224239_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09KPT_224240_285x255.jpg)
ORDER NOW
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09LPT_224248_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09LPT_224249_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09LPT_224250_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09LPT_224251_285x255.jpg)
ORDER NOW
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09SPT_226044_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09SPT_226045_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09SPT_226046_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09SPT_226047_285x255.jpg)
ORDER NOW
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09WPT_227775_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09WPT_227776_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09WPT_227777_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09WPT_227778_285x255.jpg)
ORDER NOW
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09VPT_227780_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09VPT_227781_285x255.jpg)
![](https://img.overclockers.co.uk/media/image/thumbnail/CA09VPT_227782_285x255.jpg)
ORDER NOW
