Phanteks P400A DRG Strips
2 Jun 2013
Glasgow
Hi,
I have a Phanteks P400A DRGB case which I have also installed an additional 3 fans into, I have them all daisy chained together and connected into a Tomahawk B450 motherboard.
The lights are all controlled via the case buttons on the front (not the motherboard as I only have a 4 pin header not 3 pin).
I was looking at lighting strips and the Phanteks Neon Strips are out of stock everywhere.
Can I just buy some compatible ARGB 3 pin strips from "Brazilian Rain Forest" and hook them into the D-RGB 3pin header attached to the case?
Thanks
To answer this for others.
Yes it works :)
I have the 6 fans and 2 ARGB strips daisy chained into the DRGB connectors for the fans..
All light in sync and are controlles by the case buttons.
