- 21 Apr 2007
Yes you can have the 140mm fans unobstructed by the case with some light modding
Yes exactly, and for those that think they may need to use 120mm fans at some point in the future one viewer confirmed in the comments they were able to mod the plastic at the bottom to make room for mounting the 140mm fans on the front of the core chassis.If you are going to definitely stay with 140's removing those inner strips is worthwhile.
