I have a Phanteks P600s with an XFX RX6900XT on the vertical mount which works fine. The issue I have is the clearance between the side of the case and the graphics card is only about 1/4" (6mm) so when gaming I have to open the side of the case up. Does anyone know of a case side for this with a cut out or vent in it to allow the graphics card to breath properly?
Failing that are there any cases of a similar size that have more room for a three slot card on a riser cable?
