Phanteks p600s
2 Feb 2008
Rainham - Kent
Does anyone have the new artic 420 aio in the front of their p600s case? I know it will fit length wise, but to have it to correct orientation with the pipes at the bottom wondering if there is room as the case has a cut out where they would be?
Would just be nice to see one fitted b4 I make a jump to one.
the gap at the bottom is big enough I would suggest. I have a very thick radiator in mine although as a non-AIO the tubing is at the top.
