- 17 Apr 2010
I purchased an additional Phanteks PH-F140TS fan to compliment my Phanteks- PH-TC14PE CPU cooler.
The 2 supplied fans with the Phanteks- PH-TC14PE cooler came with a splitter cable, and importantly a PWM converter cable, plugged into the CPU header on my motherboard this works flawlessly.
However the Phanteks PH-F140TS additional fan I got did not come with the PWM adapter, meaning it ran at a constant 1100rpm.
I was able to get hold of an additional PWM converter cable via Phanteks and their great customer service, however despite fitting this into the CPU_OPT header, the fan continues to spin at 1100rpm, I have tried a variety of profiles in the BIOS and using the ASUS AI SUITE but the changes made are minimal, at the most if I set the profile to a custom setting and put it on the minimum spin rate, it still spins at 1050rpm, only 50 lower than standard.
Any suggestions on what I can try, other than disconnecting it and removing, because that will be the end result if there is no fix.
Thanks,
Chris.
Thanks,
Chris.
