Phanteks ph-tc14pe and Fractal Design R6
18 Oct 2009
Hi Guys,
I'm just wondering if anyone here has a phanteks tc14pe cooler inside a design r6 case?
If so did you come across any installation problems? It's looking a tight squeeze to me (waiting on am4 brackets)
Any pics would be a bonus
Thanks
The case can take coolers up to 185mm the Phanteks will fit, only issue is ram clearance on the motherboard, what mobo do you have?
I checked the heights before ordering so i know that bit is ok, my motherboard is the x470 asus crosshair hero VII, i have x1 rear and x2 top 140 fans,
