Use the Phanteks thermal paste, it's better.
Use the Phanteks thermal paste, it's cheaper.
Gelid GC-Extreme actually blew my mind. I won't be changing to any other paste until I see proof that anything is better that is non conductive. Way better temps than my MX-2 and so much easier to use. I put a TINY blob of it on my Q6600 and at 3.24GHz 1.4v core its 49c at load on my D-14, used to max at 59 so I am very pleased with the Gelid.
Fixed.![]()
Have you read in detail the link you supplied? When idle temps are 31.25-34.5c and load temps are 83.75-101.25c and not a single ambient temp recorded??? How much did the ambient temp vary during the tests? No idea? Then resulting temps have no base and as such are almost worthless.
How do you get to that conclusion
Yeah, I don't know how Gelid and Phanteks TIM compare.
I'm sing the Phanteks supplied TIM with no complaints. Have not heard any complaints from anywhere about it.
