- 13 Nov 2007
I have my TRUE heatsink with 2x120mm push/pull fans (http://www.overclockers.co.uk/showproduct.php?prodid=FG-000-XI&groupid=701&catid=57&subcat=4) ... prime 95 gets me to 82c max with Fans @ 1250 rpm under load (ambient = 24C), Proc is an i7 920 D0 is at 4.2GHz, 1.376v under load (The 7x120mm Case fans are the same type and all about 800 rpm so the system is fairly quiet at idle). I don't plan to change the case fans ...
This cooler did my Q6600 proud for a couple of years before duty for another couple of years on the 920 so hopefully things have moved on!
How does the Phanteks PH-TC14PE compare to this?
The TRUE needs fans with good static pressure to force air through the densely spaced fins. Watercooling would be an even better option, id love to do it with my 920 but unfortunately im skint at the minute.
