Phanteks - PRE ORDER NOW!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
With amazing performance which can rival any air cooler on the market and amazing colour choices for all hardcore modders and high end gamers.
Phanteks PH-TC14PE CPU Cooler - Orange (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £79.99 inc VAT
Phanteks PH-TC14_PE twin tower thermal radiator design uses the latest aerospace technology. By using P.A.T.S to increase cooling performance and C.P.S.C Technology to enhance thermal conductivity, heat will easily dissipate, creating an opportunity for greater overclocking. Combined with Dual Phanteks PH-F140 Premium 140mm Fans, easy-to-install SoliSku mounting kit and PH-NDC thermal compound, Phanteks PH-TC14 with unique colored is setting the new standard of today’s CPU cooling.
- Intel Socket LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3 (stock backplate required)
- Fan Size: 140x140x25 , Dual Fans included.
- Fan Compatibility: 140x140x25mm x 3 pcs, (120 x 120 x25mm x 3 pcs). (Third fan clips and accessory included).
- Bearing Type: UFB bearing (Updraft Floating Balance bearing)
- Blade Geometry: 9 White colored Blades with MVB (Maelström Vortex Booster) Design
- RPM: 1200 RPM ± 10%
- RPM with Q.S.A: 900 RPM ± 10%
- Max Air Flow: 78.1 CFM
- Max Air Pressure: 1.21
- Acoustical Noise: 19 dBA
Only £79.99 inc VAT.
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Blue (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £79.99 inc VAT
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Red (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £79.99 inc VAT
ORDER NOW
Phanteks PH-TC14PE CPU Cooler - Silver (LGA 2011,1155,1156, LGA 1366, LGA775 and AMD AM2/2+/AM3) @ £79.99 inc VAT
ORDER NOW
They look awesome. Love the orange.
Showing my ignorance here, but why does it take or need two 140mm fans to achieve 78.1 cfm when a single 120mm like my Sharkoon Silent Eagle 2000 can do 76.4 cfm ?
i like the look of the blue one.......
but for £79 i dont really se a deal clincher as apose to say a Noctua or Corsair Hxx series
True, but compared to the Noctua at least it looks nice ;) Saw the red one on a ROG board, and my god it matched the board so well!
Think the blue would look awesome on my board actually. Been as my board has blue heat sinks. They are lovely looking coolers but when your on a budget like me, you think ooooo that looks really nice but then sense kicks in and decide lets shop around and get an ugly but really good cooler for a cheaper price ;)
