Hi I've recently purchased the phanteks primo case and I'm trying to get the pwn hub working. My scenario is this. I have a water cooling loop so I don't have any direct pump or heat sink that I have to plug into my mother board. I use the 4 pin pwm cable and plug it into my cpu fan header, I then use just one of my noctua fans which I have on my radiator for my master fan in slot 1, I then plug the rest of the fans into the hub. The sata power cAble is also plugged in as I have 8+ fans.
Now my problem is, when I boot up I get cpu fan error. Is this because it is not reading a fan speed and I need to set my cpu fan speed to ignore?? If I do this will it still read the temperatures so my pwm hub will still work correctly?
I have got it working but not the way the manual says so I don't actually know wether it working properly. I have my 4pin pwm cable plugged into a chassis 4 pin slot and just one of my case fans in the cpu fan header. Everything boots and all fans are turned on but I don't know wether it will be reading temps and working as it should. My motherboard is rampage v extreme.
Thanks in advance.
Thanks in advance.
