Phanteks PSU Availability and Pricing
10 Apr 2015
Hungerford, UK, Earth
mostly aimed at OCUK, any idea when the PH-P1200PS will be available. I have a phanteks Mini XL, im using the Power splitter but its a complete nightmare takes up to much room and pretty much had to sit on the case to close it . Im assuming its 1200 watt? would we be talking around the £200 mark?
According to the article on Toms Hardware the rrp is $260. Seeing that the pound is dropping near enough every day I wouldn't be surprised to see this being £250 or more. There is also going to be a 1000w version with a rrp of $230. I presume you want one due to it being able to power two systems which would allow you to get rid of the splitter?
yes the splitter is bulky and the extension cables being long, you have a birds nest of cables rammed into the hardrive area. i can use 2 psu's but thats also messy as the 2nd psu is mounted in the windowed area.. basically the mini xl case is a great idea poorly executed. i did look at their new case. but have a triple AIO on the Mini ITX board and a double on the MATX i dont think it supports this combo, looks like it needs a 120 on the min itx
(I need to update my sig with current system)
