Phanteks PWM 3 pin fan hub
17 Oct 2007
Haven't heard anything about this on the forums really but I really want this to be released.
I don't even know fully what it will be called but its from phanteks and allows you to control up to 11, 3 pin fans directly from a single 4 pin PWM fan header.
Not entirely sure how it works but appears to use pwm from a motherboard header to alter voltage from the molex (built in version) or sata (external retail version) connector? Either way it works exactly the same as the pwm fan hub in the Enthoo Primo.
My interest is because I'm looking into buying a H440 but without front drive bays I am limited in fan control options and would like to use AF120 3 pin fans. I also want to avoid multiple fan connections all over my board headers and any rear slot fan controller options.
Below is an image of the retail model from CES 2014 but there isn't much more info other than it should be released around now.
Below is the pwm fan hub from the Enthoo Primo
Will OcUK be stocking these or get further info on their release date?
I haven't really seen anything like this anywhere else other than with phanteks at the moment and the ability to control multiple 3 pin fans from a 4 pin pwm board header is a big selling point to me.
