phanteks PWM hub confusion help!!
20 Sep 2011
local
I have the entho primo case and trying to use the PWM hub.
I have a msi z97 mobo with 2 PWM headers cpu_1 and cpu_2,I have done as the manual says connect the hubs 4 pin cable to mobo cpu_fan.
I have 2 rads one with 3 e-loops fans and one with 4 e-loops fans I have connected one of the fans from the rad to the phanteks hubs fan 1 and the rest are connected to the 3 pin connectors on the phanteks hub.
I think that is correct set up? but what is happening is that all the fans stop spinning when pc is at idle!!:eek: they struggle to spin and making squeeling noises! they are b12-2 1300rpm versions.
You need to change the PWM curve in the bios
The standard PWM curve on most motherboards for the CPU header will not hit 100% RPM till the socket temp reaches 70c.Depending on the fan this would be too low a voltage/pwm value to even start the fans when idle.
Go into the bios change the CPU header fan curve to make it a little more agressive
ok thanks i will give that a go
seems to be working now:),might just plug case fans into none pwm headers as it cant be good for the fans ramping up and down all of the time?
Nice one :)
Yea you should do that.
I got my Rad fans on my CPU header so they only ramp up when gaming/benching ect and have my case fans plugged into the other Fan headers on the mobo with a different pwm curve
