Hi All,
I bought this Phanteks PSU and Cable start Kit:
What I didn't realise is that the 12VHPWR cable isn't compatible with my RTX3080Ti FE. What cable should I get for it? I have the 2x 8Pin to 12Pin adapter for the 3080ti already so should I get this:
Thanks
Phanteks Revolt Cableless 1000W ATX 3.0 PCIe 5.0 Modular 80 Plus Platinum Power Supply - White
With a Phanteks Revolt PSU, you’ll have the ideal power supply for meeting the needs of modern hardware, which you can customise with your own cables.
www.overclockers.co.uk
Phanteks Revolt Cable Kit, PCIe Gen5 Starter Set, White
Upgrade your gaming PC's power delivery with a Phanteks Revolt Cable Kit, a set of highly flexible cables manufactured from premium quality materials.
CableMod RT-Series Pro ModMesh Sleeved 12VHPWR PCI-e Cable for ASUS and Seasonic (White, 16-pin to Triple 8-pin, 600mm)
Order CableMod RT-Series Pro ModMesh Sleeved 12VHPWR PCI-e Cable for ASUS and Seasonic (White, 16-pin to Triple 8-pin, 600mm) now online and benefit from fast delivery.
Thanks
