Hi,
Phanteks have released the new version of there water blocks that will work with the new NVIDIA RTX 2080 and RTX 2080 Ti cards. As with the previous versions both models are RGB however the 2080 Ti supports Addressable RGB. The GPU blocks have been designed for the founders edition PCB with the 2080 Ti block working with both the RTX 2080 and RTX 2080 Ti.
The Glacier range is a full cover water block. The water block covers the entire PCB of the card allowing the graphics card and its VRM to remain cool and stable. The water block has a 6mm copper base for higher level of heat dissipation and heat transfer.
Phanteks Glacier RTX 2080 GPU Full Water Block with RGB Lighting - Black @ £139.99 inc VAT https://www.overclockers.co.uk/phan...-block-with-rgb-lighting-black-wc-029-pt.html
RTX 2080 Founders Edition Cards Only, Compatible with 2080, RGB Lighting, Black
Only £139.99 inc VAT.
ORDER NOW
Phanteks Glacier RTX 2080 GPU Full Water Block with RGB Lighting - Chrome @ £139.99 inc VAT https://www.overclockers.co.uk/phan...block-with-rgb-lighting-chrome-wc-02a-pt.html
RTX 2080 Founders Edition Cards Only, Compatible with 2080, RGB Lighting, Chrome
ORDER NOW
Phanteks Glacier RTX 2080 Ti GPU Full Water Block with RGB Lighting - Black @ £139.99 inc VAT https://www.overclockers.co.uk/phan...-block-with-rgb-lighting-black-wc-02b-pt.html
RTX 2080 Founders Edition Cards Only, Compatible with 2080 and 2080 Ti, Addressable RGB lighting, Black
ORDER NOW
Phanteks Glacier RTX 2080 Ti GPU Full Water Block with RGB Lighting - Chrome @ £139.99 inc VAT https://www.overclockers.co.uk/phan...block-with-rgb-lighting-chrome-wc-02c-pt.html
RTX 2080 Founders Edition Cards Only, Compatible with 2080 and 2080 Ti, Addressable RGB lighting, Chrome
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
