Phanteks T30-120 Triple-Pack radiator screws
22 Jul 2021
Belgrade
Hi,does anyone is using those on a radiator,i have EKWB 360 basic AIO,i already replaced original radiator Vardar fans with Arctic P12 pwm pst and Noctua A12 25 chromax,but i dont like sound of Noctua-s on the radiator,i like them more as a case fan and for P12 they have a weird sound in a 700-900rpm range (not that humming maybe are mine just as that i dont know),i read few reviews for phanteks but reviewers are saying that long screws are not compatibile with all radiators,does anyone know something about that,thx
They come with 2 sets of radiator screws, one for normal install and one to be used with their halos.
Okay,so in order to install t30 on ekwb rad 360 basic,i dont have to buy anything aditional,everyhing is included in a package?
Yes, you get the required screws in the pack with each fan in its own compartment. Make sure you use the 36MM ones and not the 39MM
