Hi,
Phanteks have released a new water block for the Glacier range which is designed just for Threadripper CPU's to ensure that your processor has every chip covered. The Glacier block keeps all it's original features including the RGB strips but has a big base so the whole CPU is covered.
Phanteks have also released brackets for the PH-TC14E air cooler range which can be requested by contacting them directly at [email protected]
The Glacier C399a waterblock from Phanteks is custom-designed for the TR4-socket from the ground up. Crafted to push AMD’s high-end CPU’s (RYZEN Threadripper) to its limit with a massive copper base and fin surface area. The Glacier C399a is made from premium materials, featuring integrated RGB lighting and VITON sealing from the Automotive- and Aerospace Industries to deliver the best quality possible from Phanteks.
Designed for the AMD TR4 Socket
- Custom designed for the TR4 socket from AMD
- Fine tuned to fully cover the IHS of the CPU
- Extra large cooling fin area that covers all 4 chip dies
Design
- Magnetic anodized/chrome plated aluminum cover plates
- High Quality nickel finish
- Polished acrylic surface
- Available in Satin Black and Mirror Chrome
Integrated RGB Lighting
- Compatible with Phanteks RGB equipped cases
- Industry standard RGB 4 pin adapter included for synchronisation with RGB motherboards
- Compatible with MSI mystic light sync, ASUS aura sync and Gigabyte RGB Fusion
Designed For Performance
- Integrated cooling fins made from a unibody copper base design with enlarged copper base for the best thermal capacity
- High density cooling fins, fine tuned to 0.4mm wide and designed with extra high fins (5mm) for improved conductivity
- High flow engineering reduces flow resistance for outstanding cooling performance
- Extreme cooling performance and optimal heat dissipation for heavy loads and overclocking
- Phanteks PH-NDC thermal compound with nano diamond like particles
Viton O-Ring For High Reliability
- Tailored Viton rubber sealing
- Applied in automotive and aerospace industries
- Improved durability - resistant to wear and tear during installation
- Viton retains sealing performance for long periods of time
Specifications:
- Product Type: CPU Water Block
- Compatibility: AMD TR4 for X399
- Warranty: 2 Years
- Materials:
Copper Base, Nickel plated Acrylic Cover
Aluminium Covers (Anodised/Chrome Plated)
- Water Block Dimensions: 120 mm x 42 mm x 78 mm (W x H x D)
- Copper Base Dimensions: 85 mm x 8 mm x 70 mm (W x H x D)
- Fin construction: 5mm high / 0.6mm thick / 0.4mm gap
- RGB: +12V, G, R, B
- Net Weight: 380 g (0.84 lbs)
- Gross Weight: 640 g
- Package Dimension: 135 mm x 135 mm x 65 mm (W x H x D)
Contents:
- 1x PH-C399A_BK01
- 1x PH-NDC thermal compound
- 1x RGB LED Strip set
- 1x RGB LED adapter for Phanteks case and M/B LED header
- 1x LED Y-Splitter
- 1x Solid-Sku Mounting AMD TR4
- PHANTEKS PH-C399A User Manual
Phanteks Glacier C399a TR4 CPU Water Block Acrylic Cover RGB LED - Black @ £84.95 inc VAT
RGB CPU Water Block, Compatible with AMD TR4 Sockets, Black, 2 year Warranty
Only £84.95 inc VAT.
ORDER NOW
Phanteks Glacier C399a TR4 CPU Water Block Acrylic Cover RGB LED - Chrome @ £84.95 inc VAT
RGB CPU Water Block, Compatible with AMD TR4 Sockets, Chrome, 2 year Warranty
ORDER NOW
All Phanteks Water Cooling Products Available Here
Design
Specifications:
- Warranty: 2 Years
- Materials:
Contents:
- 1x PH-C399A_BK01
- 1x LED Y-Splitter
ORDER NOW
ORDER NOW
