- 18 May 2010
- London
Im looking for a cpu cooler and looking at the Phanteks PH-TC14PE or the Noctua NH-D14.
As far as I have seen from benchmerks etc, there isnt much between the coolers, with maybe the Noctua just edging it.
However the rest of my build is basically blue so the Phantek has that in its favour.
Does anyone know if the hantek is slightly smaller than the Noctua?
The case Im going to be putting it in to is a Thermaltake Armour. Its a full size case, but does have a beefy fan on the side panel. Either of these should fit right?
If performance wise they are similar then maybe I should juts go with the aesthetics of the Phantek?
It will be cooling a 3570k and obviously I would like to get to about 4.5Ghz
