Phantom 630 vs Lancool pc k62
22 Jul 2013
Basically, this is my first build and I had my eye on the lancool k62, which was in my budget. I then however saw the 630 and thought it looked better. The only problem is its stretching the budget a bit... So ,my question is is it worth spending a bit more on a better case, or will the cheaper one suit me fine? The rig will be used for LOTS of gaming, if that's any help. Any advice will be HUGELY appreciated.
Thanks :D
If you plan on upgrading your system, a good case imho is worth paying extra for. With room for extra graphics cards, a big after market cpu fans, and lots of storage options with those movable cages the Phantom 630 is a good case. But there are plenty of cases to be had at the same price that do the same thing if the looks aren't your thing.
End of the day it's your call as to whether you want to spend a bit more on something that you're going to be spending time with sitting next to, as well as holding all your precious gaming parts.
