Phantom Case and PSU.
8 Jan 2012
Newcastle
Hi
Does any Phantom Full Tower owners use OCZ ZX Series PSU? I m not sure if the modular cables are long enough for cable management.
Or which PSU do you use in this fantastic tower?
Thank you
Two for the motherboard (8 pin EPS, 24 pin ATX) and two for the graphics card (8 and 6 pin). All of them Bitfenix alchemy braided ones. Note that there's a lot of cable hidden behind the motherboard tray and it was a pain getting it organised to put the cover back on!
The hard disk, DVD drive and fan controller (the built-in one on the top of the case) power cables were long enough without extensions.
Thanks a lot for info.. I like the way you attached the cpu radiator to the top fans.. how did you do it?
I saw loads of people attaching the radiator to the back of the 3.5 Slots
Have you tried both configurations
