- 18 Oct 2002
- North
I have a HTPC built around an Antec fusion, Gigabyte GA-73PVM-S2H, an [email protected] and 2 Seagate 7200.11 500gb drives.
All has been fine for last 10 months then computer reboots and no IDE drives are found - found that the 1st seagate is dead ( not even seen in seatools).
I get the faulty HD replaced and reloaded the OS. All has been fine for last 2 weeks... got up this morning and found that the PC had turned it self on over night out of sleep, rebooted and was stuck on the detecting IDE drives bit.... the new seagate is dead the same way as the first!!! Thoughout this time the second seagate which is kept for files has been fine. Both drives have been used on the same power cable.
Now I can accept the first seagate being faulty but lightning does not strike twice...
Could there be something causing my HD to burn out? PSU? Motherboard? External power surge? Is there any tests I can carry out?
Two things I did notice was when I installed the new HD, I could hear static interferance thru the speakers that was not there before... and last night I was watching a tv programme and fast fowarding thru some adverts - HD seemed a little noiser than normal.
