I tend to get a LOT of questions about phase, mods, and what can be done. It's very hard to put to words every mod or every variation available but I thought I'd put together a list of tested setups and what they've done before and after so people who think about having a mod done have a little knowledge behind then when they DO look.
Mach1/2 mods:
Mach units are quite good, in that they have the strongest available compressor on the market, and in the Mach2, a decent contoller. What they normally lack is both Gas, and evaporator strength.
What I'll list is the no load, and 150w load testing that I've done (comparable to an average high end single core CPU at very high clocks/load) Also, measured with a Fluke 51 on the evap close to the surface of the evap as possible)
Premod results:
Mach1 (134a gas) - -10 to -15c load, -30 to -35c no load
Mach2 (134a gas) - Same as above
Mach2GT (404a gas) - -20 to -25 load, -40 to -45 no load
VapoLS (507 gas) - -20 to -25 load, -45 to -50 no load
Post mod results:
Mach1/2 stock head with 402a regass and coilmod - -30 to -35 load, -50 to -55 no load
Mach1/2 with chilly or other evap upgrade and regass with coilmod - -40 to -45 load, -60 to -65 no load
VapoLS with new compressor (NL11F, same as Mach stock compressor) and stock head with same regass and coilmod - -35 to -40 load, -55 to -60 no load
VapoLS, same mod with evap upgrade only makes for about -40 to -45 load, -60 to -65c no load, so really for the cost, it's better for it to just have the compressor unless you're trying to squeeze evey bit of heat out of your cpu.
Mach1/2 have the nice compressor, and the new head and regass give excellent results. A regass only with these isn't too bad, but going from GT to 402a only give 10c colder on average which may or may not be what a person is looking for.
Keep in mind though, the Mach1's control system can be funny after a mod, as the reported temp at idle can reach -50 and beyond. There is an alarm and a shutdown when the temp reached and passes this, so additional mods to the electrics, or replacing the temp probe with one of a different value, needs to be done if the control system is still needed to be used.
Old VapoPE/SE/XE regassing/modding can be a little more difficult to get into simply because of the compressor itself. For that specific advice per system is really the best way.
The only drawback to the 402a, or 507 regassing for that matter, is the level of noise increase from the fans. New condensors can be fitting to the existing systems but the cost makes it something that is only of value if you're keeping the system, and you require extreme cold along with extreme quiet.
The vapoLS can still be quiet, but while the compressor is relatively small, it's designed with higher pressure and heat and that's why 507 is ok to use with relatively low fan speeds.
The use of 404a, or blended 402a setups can be quite good for those who want colder, but still the ability to use them in quieter systems. You sacrifice some of the temps, but gain the ability to use quieter fans which is nice.
I hope that gives people an idea of what to look for and what to expect from a system before and after mods. I don't list display temps much but they can be both inaccurate, and inconsistent so even the same units modded the same way can have 10c or more difference in what the display will show.
Cheers
Gray
Mach1/2 mods:
Premod results:
Post mod results:
Cheers
Gray
