no i had to flash them with latest bios but its real easy on these boards as it has ez flash in the bios so you can just use a pen drive.
99% sure u will need an older chip first\ to flash it.Will it boot up with a Phenom II making it flashable or not?
Would I need an older chip first?
You were right, the motherboard did boot with the Phenom 2 installed but i did have to update the bios to get the correct description in the bios menu.
