hey. my phenom 2 x2 unlocked to 4 at 3.1ghz is idle at between 51 and 54 degrees. on it is a arctic freezer pro 7. i have cleaned the old grease and applied fresh stuff but still cant get it down.
it started when i installed a crosshair 3 mb and a corsair psu with a ton of wires. also 2 msi 6850's. the case is a nzxt but i cant find exactly which one it is. there is 3 case fans. looking inside it it does look crammed in so airflow could be the problem.
was looking at the corsair h50 or the coolit eco.
the gpu's are running at 40 degrees.
any thaughts?
thanks
any thaughts?
thanks
