Phenom 965 C3 Initial thoughts....
6 Aug 2008
Birmingham
OK switched from a C2, I struggled with 100% stability at a mere 3.6 so ran it at stock and sometimes then it crashed (I have 4 DIMMs installed running at 1333).
This occurred regardless of what volts I was making avaliable
SO wanted to get the C3 as I suspected the memory controller was letting me down...
knock her up to 3.8 and NB to 2.4
No change to any voltage, and 100% stable, did hit 70 degrees priming but I am in a V351 case... So airflow is not incredible....
So my thoughts to anyone wondering about getting one is they are great......
Sold the old one on a well known auction site so the upgrade only cost £20 quid, deffo worth it..
yeah, i thought 62 was the max before phenom2 cpus started being damaged :S
so yeah 70 is pretty bad, unless the 965 c3 is different?
looks like you need to get a better cpu cooler if you want to keep that clock.
