OK my rig is pretty old now. I dropped in a Phenom2 965 late last year and very recently replaced the crappy PSU with a new one. It's got a bit more lease of life too thanks to a 7850 but I've never really been successful at OC'ing this chip. I recently bought a Zalman CNPS5X cooler which has taken my temps down considerably compared to stock cooler but I have to feed it 1.425v to get stable at 3.6ghz testing under Prime. This is a lot considering a lot of people report on getting around the 4ghz mark at this sort of voltage. I'm pretty sure it's down to my mobo which has never been any good - it's a bad product as you can't manually set the vcore above 1.3v and selecting auto feeds out 1.475 so I'm forced to use software to modify. Asus really did a poor job here IMO as they've never released a BIOS update to address the issue.
Does anyone have any advice on what else I should be tweaking to achieve a better higher stable clock? I know I'm not going to get 4ghz based on my cooler alone but I would have thought 3.8ghz might be a reasonable target. Or could it be the MOBO just isn't up to the job / software modding the voltage is preventing me? Your advice and opinions much appreciated
