- 17 Jan 2004
- London & Spain
Hi is there anyone out there who knows if the 9850BE will work with a Gigabyte GA-M57SLI-S4 current bios supports upto 9600 atm anyone got any experiences?
if the current bios version supports upto 9600 then probably no it won't work.. 9500/9600 are b2, 9x50 are b3Hi is there anyone out there who knows if the 9850BE will work with a Gigabyte GA-M57SLI-S4 current bios supports upto 9600 atm anyone got any experiences?
yes AM2+ motherboards are compatible with AM2 processors without a need of bios update. but the AM2 motherboard are only compatible with AM2+ processors when theres a bios update...Well, as the legend goes, AM2+ is compatible with AM2, only it'll run without the more advance power management features and HT improvements that AM2+ provides.
well before i sent mine back to amd for replacement. i tryed clocking it, it clocks to 2.70ghz on stock voltage. for 2.8-2.9ghz it needs 1.30v... i can't comment if the clocks are stable because my 9850 wasn't stable at stock,Overclocking results?
