Phenom 9850 BE Temps
1 Jul 2007
mines idling around 50 and does no seem to move much under load highest i seen is 57 so far but was wondering what others idle at? and if a TEC cooler like a Titan Amanda would be a good idea if i am gonna overclock?
Thanks in advance
Idle @ 50*C? your sure theres nothing running in background like F@H or somthing?
I'm assuming its stock 2.5Ghz right?
If you want to lower temps try a fancy CPU heatsink+Fan or try enabling Cool n Quiet on the AMD CPU.
thats seems to hot. i would have thought it'll be around 30c ida and about 38-40c load.. tomorrow i will be receiving a 9850 BE, so i will let u know what temps i get.
well i dumped on ther stock cooler for now, i do have a zalman 8700 cooler i could try but i lack artic spooge for now so it'll have to wait.
got nowt running in the background and my room is not hot or anything so temp is getting me tbh, still at stock speed and deffo want at least 3ghz outta this minimum
At stock speed it should not be ~50*C
Like gareth said ~30*C is expected.
The settings are stock? Voltages? Get some more of that AS5 and reseat Heatsink. A nice pea sized blob in the middle and squash it down with the heat sink :)
hmmmm its seems the max temps is 61c, so your temps are to hot
AMD Phenom 9850 Quad-Core Black Edition, AM2+, 2.5GHz, 4MB Cache, 125w.
Processor AMD Phenom™ X4 Quad-Core
Model 9850
OPN Tray HD985ZXAJ4BGH
OPN PIB HD985ZXGHBOX
Operating Mode 32 Bit Yes
Operating Mode 64 Bit Yes
Revision B3
Core Speed (MHz) 2500
Voltages 1.20/1.25V
Max Temps (C) 61'C
Wattage 125 W
L1 Cache Size (KB) 128
L1 Cache Count 4
L2 Cache Size (KB) 512
L2 Cache Count 4
L3 Cache Size (KB) 2048
CMOS 65nm
Socket AM2+
u could try the zalman 8700 cooler , it should be better than the stock cooler...
i'll be using Akasa AK-922 EVO tomorrow, so hopeful i won't have heat issues
do you have bios fan speed control turned on?
eg, the abit ax78 defaults to fan speed control on with a ramp up from min (30%) at ~35c cpu to max (100%) at 55c or simmilar.
decided i was gonna stick we the stock cooler as i was reading some thermal compounds take a few days to settle to best preformance, cpu idles around 35 now and about 45 loaded......
I got an xclio windtunnel case with space for 2 more 120mm fans so might see about digging a couple up..... now the question is do i get plain ones or one's with nice blue led's to match the case:rolleyes:
