Phenom I and Phenom II, the difference ?
Phenom 2's are a bit faster clock for clock, come with higher speeds out of the box, overclock much better and consume less power. They're all round better chips, although their price reflects this.
so far i've found this isn't the case in 64bit os's. its just the same as the phenom 1. in vista 64bit i can only get to 3.4ghz on sock volts (1.35v) on 32bit it can easyly get 3.6-3.7ghz+ on sock volts (1.35v)
but i'm still very happy with it. its so fast even at stock. and the temps are great 26c idle, 35 load @ 3.4ghz.
The Phenom I is a pretty power hungry beast, bad times considering the performance.
The Phenom II actually looks to be alright power wise, especially with the performance it offers.
I current have a AMD 9950 Quad core Black edition overclocked from 2.6Ghz to 3.0ghz, had to increase voltage though to 1.375 which is still alright. Could probaly go higher but i think its well fast already :)
There is nothing to resolve as there is no issue.
64bit OS puts more strain on the CPU as its using all of its as it were instead of half of it in 32bit OS.
We use some programs over others to test stability as others would not show any instability as they don't push the CPU enough.
The same happens to the GPU when overclocked with some games not pushing that hard & others crashing the gfx card at the same overclock.
An issue would be an unstable CPU at stock on a given OS as that's all they are guaranteed for, and not guaranteed to be stable when overoclocked to the same degree across all OS & applications.
so intel chips do the same? some people told me no..
