I've tried searching on the net for answers but I can't seem to find anything.
So what the problem is is that the temperature fluctuates randomly every now and again and because my fans are controlled via PWM it bumps them all upto 100% for 2 - 3 seconds then back down to normal.
My 1090T is overclocked to 3.8Ghz (all stock volts) so I set the speed back to default and the same problems occur, even with cool n quiet enabled it happens. I also tried loosening the clamp on the H70 to see if that was causing the temperature spikes but again it still occurs.
I haven't done anything stressful this morning and it is currently at an idle temp of 32°c but hardware monitor is reporting that it has gone upto 51°c at some point. Under full load it is around about 48°c with the temp fluctuating to as high as 68°c.
If anybody has any ideas as to why it is doing this or any solutions that would be great!
