- 11 Jul 2009
Basically my phenom 940 is at stock speed (3.0 ghz) and runs at 41deg idle and 61/62deg under heavy load. Are these temps unusually hot?? and will they cause any damage to the cpu?
I use the arctic cooling frezer 64 pro on the cpu so i thought my cpu temp would be much lower. (When i run it at full speed in bios at ~2200rpm the cpu cools to 32deg but using smartfan control is usually spins at under 1000rpm.)
