Phenom II
Some boards req. a bios update to work with the PIIs. Generally AM2+ is good enough for the PIIs.
Have a check on the manufacturer website to be sure.
1. Supports AMD Phenom / Athlon series processors
2. Dual Channel DDR2 1066* for remarkable system performance
3. Integrated ATI Radeon HD3200 graphics (DirectX10)
4. Ultimate graphics performance with dual PCI-E 2.0 x16 interface with ATI Hybrid CrossFireX support
5. Integrated SATA 3Gb/s with RAID function
6. Features high speed Gigabit Ethernet and IEEE1394
7. High quality 106dB SNR ALC889A HD audio
8. Integrated HDMI/ DVI interface with HDCP
9. All Japanese manufactured solid capacitors
* DDR2 1066 is supported with combination of AM2+ processors and DDR2 1066 memory modules, please refer "Memory Support List" for detail memory support information.
That is what's said on the manufacturers website
uuuh the Gigabyte website is horrible, it wont seem to work for me, check the CPU support list for the board you have.
I know for my Asus board some PIIs are listed, if you don't have them listed for you then you wont be able to run it properly.
I have this Mobo too, works great with the Phenom II's. I don't own a phenom myself yet, but a friend let me borrow his to test if it worked and it flies along.
