quote:
but are these older AM2 boards going to severly cripple the performance of Stars processors?
I highly doubt it. The only time this should have any effect at all is if the current Hypertransport bandwidth (4.0GB/s in either direction) is insufficient for your I/O. The one time that it's likely to have a noticeable (easily 10%) effect will be on system boards with integrated video when playing 3D games. Such a setup sends a LOT of data between memory and the motherboard chipset and right now Hypertransport is a bottleneck (4.0GB/s of bandwidth vs. up to 12.8GB/s from main memory). There may also be a TINY difference in really high-end 3D video setups with add-in cards, particularly if you're talking about Crossfire or SLI setups. However considering that a single PCIe 16x video card is limited to 4.0GB/s in each direction as well, HT 1.0 isn't much of a limitation here, we're probably looking at less than a 5% difference in performance.
The real advantages for HT 3.0 will only be realized in server and I/O intensive workstation applications in the near future. If you've got a 16+ 15Krpm SCSI disks in multiple RAID arrays and dual 10-gigabit Ethernet adapters, then HT 3.0 will be a godsend. For desktops though there just isn't that much I/O and Hypertransport 1.0 already provided a LOT of bandwidth.
