Every once in a while when a start my computer, the CPU is not acting normal. Right now as I type this, the max cpu speed is 1.6Ghz, the core voltage is 1.472 and the temperature are in 50c+ in idle. CPU usage is less than 5%. Also in CPU ID it no longer says "Phenom II X6 1090t" in the specification window but "AMD Engineering Sample (ES)"
When it runs normal, it runs at 3.2Ghz the core voltage is 1.400 and the idle temps are around 35c. It also says "Phenom II X6 1090t" in CPU ID. I have cool and quiet turned on so I don't know if this is causing this problem.
One more thing, when I first bought this computer the cpu voltage was 1.55v at load so I manually set it to 1.400 because I heard that anything over 1.45 is too much. I am using Gigabyte GA-880GM-UD2H motherboard and stock cooling fan. The motherboard has got F7 bios which is one of the latest versions so I don't think that's the problem.
Any ideas why my CPU is acting strange? I am baffled why the cpu clock speed is at max at 1.6Ghz even if I am ruining prime95 and stressing all cores 100% and why my temps are so high in idle? Usually when the CPU runs fine I get 50c when the CPU is at load at 3.2Ghz.
Thx for any help
Thx for any help
