- 7 Aug 2004
As title, there seems to be a lot of confusion around the net here, me included.
Iv got mine currently at 3.85ghz 1.4375volts in bios, goes to 1.45 under LYNX.
Asus PC probe is reading: 65c under load
CPUID HW reads CPU same, 65c, however its reading the 6 cores at 46c under load
CORE TEMP 0.99.8 reads the same as CPUID at around 46 for all cores under load. It also informs me my Ti.MAX is 90c
NOW WHATS GOING ON HERE, I know AMD aint accurate for temps but this is silly, apparently 62c is the limit on these chips and im not exactly thrashing it.
My cooling is a firmly bolted down silver arrow with 3x140mm fans in a HAFX case, so i know iv got good air flow.
Given my cooling tech im more inclined to believe the 46c load temp reading, the heatsink is very very warm but not like OMGZ im gonna get burnt.
Seriously guys, what knowledge do you have? I know this CPU can hit nearly 4.2 due to the previous owner but im not getting these temp readings here, its all over the shop, yet more software reads 46c load, would this be more likely ?
