Philips Momentum 326M6VJRMB advice
22 May 2020
need a decent hdr monitor for ps4 pro use mainly but also for pc gaming at 1440p.I dont play fast competitive games on pc either. Is this an ok monitor
update
narrowed it down to these 3 monitors now
asus cg32uq
philips 326m6vjr
samsung c32g7 odyssey
any advice
Asus and phillips are both 60hz panels so the Samsung beats them both in terms of specs but it's not 4k like the other 2. Unless you're planning on one of the new nvidia cards you wont be gaming at 4k with the pc so I'd go for the Samsung personally. If you have a large budget the best you can get is the £1500 LG 48"cx oled, that's hdmi 2.1 with 4k at 120hz. If you're not concerned with screen size you could use some other tvs, some are great now for PC gaming and some of LG's mid range TVs like the lg um7400 come with ALLM and the 43" model is only about 380 quid. If you can spend a grand you can get the Sony Xh9005 55" which has hdmi 2.1 and can do 4k at 120hz so will be future proof.
