Not sure if I can link to the Philips official website as it has a shop, but I'm able to get a Philips OST690/10 for £50. I would use it around the house and taking to house parties etc, it is a bit bigger than most portable speakers and but it does have two speakers that are 4" diameter..
I'm not sure however if the speakers would actually be any good? There's not many reviews out there, but I am not sure what I should be looking for. It would pretty much be limited to using spotify/soundcloud and mobile phones to stream music to the device for the occasional party and just around the house. The specs are:
Specifcations
Amplifer
Max Output Power 6W per channel x 2
Frequency Response 125 -16000 Hz, -3dB
Signal to Noise Ratio >55 dBA
Total Harmonic
Distortion <1 %
Audio-in Input 650 mV RMS
Tuner
Tuning Range 87.5 - 108 MHz
Tuning Grid 50 kHz
Sensitivity
- Mono, 26dB S/N Ratio
- Stereo, 46dB S/N Ratio <22 dBf
<41 dBf
Total Harmonic Distortion <3%
Signal to Noise Ratio >50 dBA
Bluetooth
Standard Bluetooth Standard Version 2.1+EDR
Range 10m (free space)
Speaker
Speaker Impedance 8 ohm
Speaker Driver 4"
Power supply
- AC Power
- Battery 220-240 V~, 50/60 Hz;
6 x 1.5 V R14/UM2/C
Operation Power
Consumption 15 W
Standby Power
Consumption <0.5 W
Max. Loading (USB) 5 V 1 A
Dimensions - Main Unit
(W x H x D) 447 x 230 x 116 mm
Weight (Main Unit) 2.2 kg
I'm not too concerned about needing batteries or the size, but I am concerned about sound quality. Do the specs read that the speaker quality is decent? The radio is just a nice bonus.
If anyone can advise, I'd appreciate it.
Specifcations
Amplifer
Total Harmonic
Distortion <1 %
Tuner
Tuning Grid 50 kHz
Sensitivity
<41 dBf
Bluetooth
Speaker
Speaker Driver 4"
Power supply
- AC Power
6 x 1.5 V R14/UM2/C
Operation Power
Consumption 15 W
Standby Power
Consumption <0.5 W
