Phillips Hue Compatible light switch for non HUE bulbs?
6 Nov 2002
London UK
Most of my house if now fully fitted with Hue bulbs with the exception of the kitchen, due to a lack of forward thinking our kitchen current has eight dimmable sealed unit down-lights all currently hooked up to a glass fronted touch switch.
Rather than replacing all the lights with new GU10 housings and fitting Hue bulbs I wondered if I could swap out the wall switch with a new unit can do the following:-
Integrate with Hue and show up as a single light which can be turned on/off by Hue apps or smart devices
Include a button allows you to turn the lights on/off by the switch itself
Include a button that allows you to control the dimmer value (optional)
Does such a device exist?
Thanks
Yes plenty, the cheaper ones require a neutral wire though.
Just search for "hue switch"
The others cost about £50+ each.
Search for "friends of hue switch"
