- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
Phobya fans have landed at OcUK!
Take a look at our new range
Phobya Nano-G 12 PWM 1500rpm RED LED Case Fan @ £10.99 inc VAT
Phobya's new masterpiece of cooling technology with PWM technology!
This is a fan that will satisfy both Silent-PC users and performance-oriented PC builders which is unique on the fan market. This innovative fan will bring fear to its competitors and keep your system cool with all of its great features!
The manufacturer's consortium Phobya has achieved that an increased Airflow does not necessarily result in higher noise emissions by using an innovative fan blade design. The specially curved fan blades in combination with the unique design and high fan blade density lead the way to the future of cooling! The bearing is quipped with the newest Nano technology which greatly reduces friction and noise emissions. The innovative motor design in combination with an optimally chosen fan speed does the rest to provide exceptional performance and quiet operation.
At full speed even the most modern fan will become audible. Therefore the Phobya fans are designed to handle lower voltages well which allows operation in a voltage range of 5-12V. This gives the option of a virtually inaudible operation whilst a strong Airflow will still keep your system cool.
The appearance nowadays also is an extremely important factor when considering a fan. The red fan blades in combination with an elegant black frame, completely in an elegant glossy finish result in a truly spectacular appearance of this fan which is a great choice for any system! NEW: The PWM version of the Phobya fans now has a red LED in every corner. The LEDs can be switched on and off using a small button attached to the fan.
For cleaning of the fan the full rotor can be removed by lightly pulling on the frame respectively. Therefore cleaning of the fan can easily be accomplished: Simply hold the fan under running water and rinse off dust and dirt. After a short drying period the fan can be reassembled by simply pushing the rotor back into the casing and the fan can be used again.
- Dimensions: 120x120x25mm
- Color: Black frame, red fan blades and NEW only with the PWM version: Red LEDs
- Weight: 122g
- Nominal voltage: 12V
- Starting voltage: 7V
- Current draw: 0,45A
- Nominal speed: 600-1500rpm (+/- 10%)
- Airflow: max. 107,76m³/h / 63,44CFM
- Noise emission: 10-25 dB(A)
- MTBF (25°C): 100.000hrs
- Connector: PWM
- Max. static pressure: 1.6mm-H2O
Only £10.99 inc VAT.
ORDER NOW
Phobya G-Silent 12 1500rpm RED LED Case Fan @ £6.98 inc VAT
Phobya's new masterpiece of cooling technology!
This is a fan that will satisfy both Silent-PC users and performance-oriented PC builders which is unique on the fan market. This innovative fan will bring fear to it's competitors and keep your system cool with all of it's great features!
At full speed even the most modern fan will become audible. Therefore the Phobya fans are designed to handle lower voltages well which allows operation in a voltage range of 5-12V. This gives the option of a virtually inaudible operation whilst a strong Airflow will still keep your system cool. The fan is shipped with cables for voltage reduction. These cables reduce the voltage to 7V or 5V as desired. All cables are sleeved black which supports the elegant and sleek appearance of the fan.
The appearance nowadays also is an extremely important factor when considering a fan. The red fan blades in combination with an elegant transparent frame and red LEDs, completely in an elegant glossy finish result in a truly spectacular appearance of this fan which is a great choice for any system!
This bundle contains three fans (Art.No.: 78216) and offers sensational savings compared to individual purchases.
- Colour: Transparent frame, red fan blades & red LEDs
- Weight: 119g
- Starting voltage: 5V
- Current draw: 0,2A
- Nominal speed: 1500rpm (+/- 10%)
- Airflow: 97,20m³/h / 57,22 CFM
- Noise emission: 25 dB(A)
- MTBF (25°C): 50.000hrs
- Connector: 3Pin
- Max. static pressure: 1.61 mm-H2O
Only £6.98 inc VAT.
ORDER NOW
Phobya G-Silent 12 1500rpm Blue LED Case Fan (120x120x25mm) @ £6.98 inc VAT
Phobya's latest marvel of cooling Technology!
A fan of both Silent lovers and friends of the performance-optimized system addresses is an absolute novelty in the cooler segment. But this split and still have more talent that fans of other pale with fear, "Fear it!
The consortium of manufacturers' Phobya "it has achieved through optimum alignment of the blades that increased air flow does not necessarily lead to higher noise levels. The rotor blades are curved in combination with the wedge-shaped alignment of the camp to show the context, the future starts here! The camp combines sash and frame to a minimum point, the drive through coils, ensures that this is almost noiseless, silent fans know what really appreciated. By increasing the speed, here was an air flow rate reached it's so rare!
At a speed of 1500rpm and the latest fan is audible. Therefore, this fan has been designed so that even he has to make do with less tension good. For a start voltage range from 5 to 12V, this fan will be quieter than a gnat, yet the system is still held by a strong air current is very cool! The cable is gesleevet know what's appearance on the fan.
The look is another point which takes in addition to functionality, a high weighting. Blue blades with elegant transparent framework, with fully polished look with the red LEDs create a eye-catcher in the system where each user can say to himself: This fan is a good choice!
Technical details:
Dimensions: 120 x 120 x 25mm
Color: transparent framework, blue blades and blue LEDs
Weight: 119g
Rated Voltage: 12V
Start voltage: 5 V
Power consumption: 0.2 A
Rated speed: 1500rpm (+ / -10%)
Airflow: 97,20 CFM / 57.22 CFM
Noise level: 25 dB / A
MTBF (25 ° C): 50000 hours
Connector: 3 Pin
Max Static Pressure: 1.61 mm-H2O
Feature: Lighted with 4x blue LEDs
Only £6.98 inc VAT.
ORDER NOW
Phobya Nano-G 12 Silent waterproof 1500rpm Multioption Case Fan @ £9.98 inc VAT
- Weight: 119g
- Current draw: 0,22A
- Airflow: 107,76m³/h / 63,44CFM
- Connector: 3Pin
Only £9.98 inc VAT.
ORDER NOW
Phobya Nano-G 12 PWM Silent 1500rpm Double Blade RED LED Case Fan ( 120x120x25mm ) @ £10.99 inc VAT
- Weight: 122g
- Connector: PWM
ORDER NOW
Phobya Nano-G 14 PWM Black Silent Edition case Fan ( 140x140x25mm ) @ £10.99 inc VAT
The consortium of manufacturers' Phobya "it has achieved through optimum alignment of the blades that increased air flow does not necessarily lead to higher noise levels. The rotor blades are curved in combination with the wedge-shaped alignment of the camp to show the context, the future starts here! The camp, which was equipped with the latest Nano Technology combines sash and frame to a minimum point, the drive through coils, ensures that this is almost noiseless, silent fans know what really appreciated. By increasing the speed, here was an air flow rate reached it's so rare!
At a speed of 1100rpm and the latest fan is audible. Therefore, this fan has been designed so that even he has to make do with less tension good. For a start voltage range from 7-12V, this fan will be quieter than a gnat, yet the system is still held by a strong air current is very cool! The scope of supply for the reactors of the same speed, even included a matching cord. This reduces the voltage at 7 volts, depending on taste. All cables are black gesleevet, demonstrating the appearance of the fan.
The look is another point which takes in addition to functionality, a high weighting. The transparent black frame and blades is accompanied by his Schlichtig convinced by the blue LEDs again gently. Decorated like a grand piano in the living room, this is a whole new eye candy in the system where each user can say to himself: This fan is a good choice!
To clean the fan, the entire rotor can, by slightly, from the frame and engine are removed. To clean is carried out smoothly. Just hold it under running water and rinse the dust. After a short drying period, the cooler by gently squeezing in the original state are returned to the fan and you can start work again.
- Dimensions: 140 x 140 x 25mm
- Colors: transparent black frame, transparent black blades, blue LEDs
- Weight: 150g
- Rated Voltage: 12V
- Start Voltage: 7 Volts
- Power consumption: 0.15 A
- Rated speed: 600-1100rpm (+ / -10%)
- Airflow: max. 100m ³ / h / 58.86 CFM
- Volume: 10-24 dB / A
- MTBF (25 ° C): 100000 hrs
- Connector: PWM / 4 pin fan connector
- Max Static Pressure: 1.85mm-H2O
ORDER NOW
Phobya G-Silent 14 1100rpm Red LED Case Fan ( 140x140x25mm ) @ £6.98 inc VAT
Phobya's newest masterpiece of cooling technology!
A fan which appeals to both silent-enthusiasts and users of high-power systems is something all-new in the cooling sector. These features and the additional talents of this fan make the competition "Fear It"!
The manufacturer consortium Phobya has achieved the exceptional compromise of not increasing noise emissions whilst improving airflow.
This was made possible by adjusting fan blade angle and geometry as well as the implementation of many other design features. This fan is the future! A bearing which connects fan and frame with minimal flow resistance, a highly developed motor and rigid frame as well as special blade geometries: This is what makes this fan so quiet whilst maintaining excellent performance. The increased fan speed allows increased Airflow for added performance.
At a speed of 1100rpm even the most advanced fan becomes audible. Hence this fan was designed to also run at lower voltages. With a starting voltage of 7-12V this fan can become as quiet as a whisper and still maintain strong airflow for powerful cooling. The cable is enclosed in white sleeve, underlining the design of the fan.
Looks are another factor which was considered besides functionality. Blue fan blades with an elegant transparent frame, completely in high-gloss design with red LEDs, creating an eye-catcher for in the system. This fan is truly a great choice!
- Colour: Transparent frame, Red fan blades and Red LEDs
- Weight: 140g
- Current draw: 0.17A
- Nominal speed: 1100rpm (+/-10%)
- Airflow: 90m³/h / 53 CFM
- Noise level: 24 dB(A)
- Connector: 3-Pin
- Maximum static pressure: 1.61 mm H2O
- Special features: 4 integrated red LEDs for lighting
Only £6.98 inc VAT.
ORDER NOW
Phobya Nano-G 14 Silent Waterproof 1000rpm 140mm Fan @ £9.98 inc VAT
At full speed even the most modern fan will become audible. Therefore the Phobya fans are designed to handle lower voltages well which allows operation in a voltage range of 7-12V. This gives the option of a virtually inaudible operation whilst a strong Airflow will still keep your system cool. The fan is shipped with cables for voltage reduction. These cables reduce the voltage to 7V if desired. All cables are sleeved black which supports the elegant and sleek appearance of the fan.
- Dimensions: 140x140x25mm
- Weight: 138g
- Nominal speed: 1000rpm (+/- 10%)
- Connector: 3Pin
Only £9.98 inc VAT.
ORDER NOW
Phobya G-Silent 18 700rpm Slim White Case Fan ( 180x180x25mm ) @ £9.98 inc VAT
Silent systems at a reasonable price, this is only possible with Phobya!
The consortium of manufacturers' Phobya "it has achieved through optimum alignment of the blades that increased air flow does not necessarily lead to higher noise levels. The rotor blades are curved in combination with the wedge-shaped alignment of the camp to show the context, the future starts here! The camp, which connects the sash and frame to a minimum point of each other, the drive of coils and an ultra-resistant exterior, which absorbs the shear forces has been achieved so that this fan is almost noiseless, silent fans know what really appreciated. 17 dB / A is a treat if you have the air flow of 95 m³ / h in mind. Exercise extreme Phobya made it enjoyable as their system has zuzufächern coolness!
Of course, this model can even quieter! This fan designed so that even he has to make do with less tension good. For a start voltage range from 7-12V, this fan will be quieter than a gnat, yet the system is still held by a strong air current is very cool!
Another highlight is the "Slim version"!
Slim means the fan is narrower than the standard, only 25mm thick! This opens up during assembly in the housing, particularly in combination with radiators, fewer restrictions. This modification allows for a number of more opportunities to build a silent system. Now the price and design considerations are not a problem everything!
- Dimensions: 180 x 180 x 25mm
- Colors: white frames and blades
- Weight: 215g
- Start Voltage: 7V
- Power consumption: 0.13 A
- Rated speed: 700rpm (+ / -10%)
- Airflow: 95 m³ / h / 56 CFM
- Noise level: 17 dB / A
- Connector: 3 Pin Molex
- Feature: very narrow, 25mm
Only £9.98 inc VAT.
ORDER NOW
Phobya G-Silent 18 700rpm Slim Black Case Fans ( 180x180x25mm ) @ £9.98 inc VAT
Silent systems at an affordable price - That's only possible with Phobya!
A fan which appeals to both low-noise enthusiasts and performance-oriented users: This is something completely new on the cooling sector. This and the many more features make the competition shake in fear: "Fear it!"
The manufacturer consortium Phobya has achieved the exceptional compromise of not increasing noise emissions whilst improving airflow. This was made possible by adjusting fan blade angle and geometry as well as the implementation of many other design features. This fan is the future! A bearing which connects fan and frame with minimal flow resistance, a highly developed motor and rigid frame as well as special blade geometries: This is what low-noise enthusiasts know to appreciate. 17 dB(A) are a true pleasure, especially with the flow rate of 95 m³/h in mind. This fan is truly an improvement for any system!
Of course even this fan is capable of even more quiet operation. The design allows it to run at lower voltages, with a starting voltage range of 7-12V it is possible to operate it at a virtually inaudible speed whilst still achieving plenty of airflow.
Another highlight is the "slim version":
With a thickness of only 25mm the fan is only as thick as a standard 120mm fan! This gives many more possibilities for mounting in the enclosure, especially in combination with radiators. With this innovative new fan the many problems of 180mm fans are now a thing of the past!
- Dimensions: 180x180x25mm
- Colour: Black frame and fan blades
- Weight: 215g
- Anlaufspannung: 10V
- Betriebsspannung: 7 -12V
- Current draw: 0.13A
- Nominal speed: 700rpm (+/-10%)
- Airflow: 95 m³/h / 56 CFM
- Noise level: 17 dB(A)
- Connector: 3-Pin Molex
- Special features: Slim version, only 25mm thick
Only £9.98 inc VAT.
ORDER NOW
Phobya G-Silent 18 700rpm Red LED 180mm Fan ( 180x180x32mm ) @ £15.98 inc VAT
Technical specifications:
Dimensions: 180x180x32mm
Weight: 432g
Power consumption: 3W
Nominal speed: 700rpm (+/- 10%)
Airflow: 169 m³/h /100 CFM
Noise emission: 18 dB(A)
Connector: 3Pin
Special feature: 4x red LEDs
Only £15.98 inc VAT.
ORDER NOW
- Weight: 122g
- Connector: PWM
ORDER NOW
- Weight: 119g
- Connector: 3Pin
Only £6.98 inc VAT.
ORDER NOW
Technical details:
Weight: 119g
Rated Voltage: 12V
Start voltage: 5 V
Connector: 3 Pin
Only £6.98 inc VAT.
ORDER NOW
- Weight: 119g
- Connector: 3Pin
Only £9.98 inc VAT.
ORDER NOW
- Weight: 122g
- Connector: PWM
ORDER NOW
- Weight: 150g
ORDER NOW
- Weight: 140g
- Connector: 3-Pin
Only £6.98 inc VAT.
ORDER NOW
- Weight: 138g
- Connector: 3Pin
Only £9.98 inc VAT.
ORDER NOW
- Weight: 215g
- Start Voltage: 7V
Only £9.98 inc VAT.
ORDER NOW
- Weight: 215g
Only £9.98 inc VAT.
ORDER NOW
Weight: 432g
Connector: 3Pin
ORDER NOW
