I had one once. Mine was made by icute and the psu is a Winpower. Removeable motherboard tray on a cheap case was unexpected but cooling is'nt great. Only a single 120mm exhaust. You can fit a 80mm at the front but the intake is mostly blocked. You are seriously limited with cpu coolers as well as the available height is very low. Stock cooler's are about it and the psu sit's right over it. I got rid of mine as it was just too hot running.
Well ordered with it is a AMD phenom II quad, 2 x hdds, and a silent gpu ( low ati one can remeber it off memory, and a Scythe Shuriken Rev.B Quiet Low Profile CPU Cooler, would that be ok?
