Phoenix Gas Help?
10 Sep 2008
Bangor, Northern Ireland
If anyone has a Phoenix Gas Pay as you go meter, do you know how to turn back on your gas connection once you run out? Ive topped it up and it gives me the new gas balance but it flashes "off" every couple of seconds and ive now got no hot water :( Theres only the two buttons and neither of them have worked for me so far.
Any help would be great
Thanks
When mine ran out, i had to hold the B button down for 10 seconds or something. It's made idiot proof in case you've left half a dozen gas appliances turned on.
Yeah turns out i had to turn the gas supply off, hold in the A button and flick it back on again and then reset the boiler...not exactly what id call idiotproof :) Maybe im just an idiot though.
