Photo colours changing when ordering prints
28 Feb 2009
Anyone know why this is happening. I'm ordering some prints from DSCL
Some of them are fine but some of them have gone weird like this one. All are edited in PS and saved as RGB JPG
Yeah its sRGB, its something to do with Photoshop as any images I have exported from Lightroom are fine!
Are there any settings I should check in PS?
Other than double checking it is sRGB in the colour settings (check in Adobe RAW converter that it is also sRGB, the default is Adobe), no idea. Normally AdobeRGB mutes colours like the image there which is why I suggested it.
I suspect the browser my be at fault here as Google disabled monitor profiles a while ago in Chrome, have you tried Firefox or IE?
Your monitor may not be calibrated, and you should use soft proofing to ensure that prints come out the same as they look on the computer.
